Webinar on Demand
How to Leverage Data Integration
& Streamline Self-service analytics
Duration: 40 minutes
These days every manufacturing plant collects a tremendous amount of data and has many business applications for specific processes related to production. Think of the hundreds or thousands of connected assets where temperatures, pressures, flows etc. are being measured. Not to mention the lab data being collected, the spot checks being performed, and so on.
In this webinar, you will learn how you can easily integrate your different types of data – time series, asset, or contextual – that resides in various systems and sources to gain much better visibility into your operations and save time, money, and resources.
Discover how you can:
- Integrate your data to provide operations and engineering departments an easy and consistent way to generate insights and take appropriate, timely actions
- Unlock data silos and use the results in other applications via import-export techniques, APIs, and more
- Easily incorporate self-service analytics into your existing IT landscape
About Speaker
Nick is a chemical engineer whose passion is solving problems through collaboration and data driven decision making. As a Customer Success Manager at TrendMiner, Nick draws on his extensive experience in manufacturing and data analytics to lead customers through use case resolution.
Nick holds a Bachelors of Science in Chemical Engineering from the University at Buffalo. Between 2011 and 2018 Nick worked as a Technology Engineer at BASF Corporation. Nick was responsible for capital projects, process troubleshooting, plant optimization, debottlenecking, automation, and digitalization efforts.
