A drop in sulfur recovery could have environmental and regulatory effects, so engineers used TrendMiner to save this solution for the future.
Condition-Based Monitoring of Pygas Stripper in a Steam Cracker
Inspirational Use Cases, Oil-and-gas (iuc), Use Cases PDF Plant Manager, Process Engineer Advanced Asset, Continuous Improvement, General, Operational Performance, Predictive Maintenance, Quality Improvement Asset Chemical Generic, Oil & Gas Use CaseEngineers used TrendMiner to create condition-based monitoring of fouling in a Pygas stripper so they knew the right time to clean.
Developing Energy Balance Models for Condition-Based Monitoring
Chemicals (iuc), Inspirational Use Cases, Use Cases PDF Plant Manager, Process Engineer Advanced Continuous Improvement, Net-Zero Operations, Operational Performance, Predictive Maintenance, Quality Improvement, Sustainability Continuous Chemical, Oil & Gas Chemicals, Energy, Oil & Gas Use CaseThis petrochemical plant used TrendMiner to create energy balance models and determine when 17 bar steam consumption was excessive.
When an oil company needed to figure out the flow rate from a well, it used TrendMiner monitoring to keep the wells operational and prevent sudden shutdowns.
When a faulty valve caused unwanted flare spikes and environmental concerns, engineers used TrendMiner to find the root of the problem.
Quick Links
Blog Posts
- Achieve Better Operational Storytelling with a Connected Factory8 April 2024 - 15:44
- New Event Analytics Capabilities, Custom Calculations, and Better Operational Agility – Welcome to TrendMiner 2024.R11 April 2024 - 17:43
- Navigating the IT/OT Convergence in Pursuit of a Smart Factory12 March 2024 - 10:11
