Discover the software, get technical information on all its key features, as well as practical examples of how these capabilities can help you every day.
A drop in sulfur recovery could have environmental and regulatory effects, so engineers used TrendMiner to save this solution for the future.
Engineers used TrendMiner to learn when to clean the aeration elements used in biological wastewater treatment despite a high variance of variables.
This chemical company used TrendMiner to find a hidden relationship between organic acids and wastewater quality after a certain time frame.
When an oil company needed to figure out the flow rate from a well, it used TrendMiner monitoring to keep the wells operational and prevent sudden shutdowns.
Engineers used TrendMiner to find the root cause of waste gas emission spikes quickly, which improved safety and helped the company achieve net-zero operations.
When a plant suffered from coking problems and shutdowns as its product cooled, engineers used TrendMiner to determine how to keep the factory operational.
This plant lost 25% of the particles that dropped through its prill tower until engineers discovered while using TrendMiner that cooler temperatures made a better product.
A utility gained $260,000 in business value after TrendMiner helped it determine when to calibrate the inlet valves for its natural gas generator.
Using TrendMiner features, chemical engineers can forecast the normally unpredictable useful life of a catalyst bed for more accurate production scheduling.
