Take control of your energy consumption with our Energy Management Dashboard. Monitor, analyze, and optimize your energy usage in real-time.
Finding the Right Time to Clean Aeration Elements
Inspirational Use Cases, Use Cases, Water & wastewater (iuc) PDF Data Scientist, Plant Manager, Process Engineer Beginner Asset, Continuous, Downtime Reduction, General, Net-Zero Operations, Operational Performance, Predictive Maintenance, Quality Improvement, Sustainability Asset, Continuous Water & Wastewater Water & Wastewater Use CaseEngineers used TrendMiner to learn when to clean the aeration elements used in biological wastewater treatment despite a high variance of variables.
Reducing Pump Shutdowns with Live Monitoring and Alerts
Inspirational Use Cases, Use Cases, Water & wastewater (iuc) PDF Plant Manager, Process Engineer Beginner Asset, Asset Reliability, Continuous Improvement, Downtime Reduction, General, Operational Performance, Predictive Maintenance, Sustainability Asset Water & Wastewater Water & Wastewater Use CaseBecause pumps are such a critical part of the water treatment process, engineers needed a better way to know which pumps were online and which had failed.
Engineers at this wastewater treatment plant learned using TrendMiner why its pH levels were higher after a partial pipe replacement project.
This chemical company used TrendMiner to find a hidden relationship between organic acids and wastewater quality after a certain time frame.
This reverse osmosis company violated government energy usage regulations each month until TrendMiner revealed how pump and skid timing could keep it compliant.
