Process experts used TrendMiner to identify correlations between the ambient temperature and the power output of the cooler.
Creating an Anomaly Detection Model to Prevent Plant Shutdown
All industries (iuc), Chemicals (iuc), Inspirational Use Cases, MLHub (icu), Use Cases PDF Data Scientist, Plant Manager, Process Engineer Advanced Continuous Improvement, Cost Reduction, Downtime Reduction, Increase Yield, Machine Learning, Operational Performance, Predictive Maintenance, Quality Improvement, Waste Reduction Continuous, Machine Learning Chemical, Data Science - Cross-industry Chemicals, Data Science Use CaseLearn how you can use self-service analytics software to reduce downtime by setting up anomaly detection models.
This plant lost 25% of the particles that dropped through its prill tower until engineers discovered while using TrendMiner that cooler temperatures made a better product.
Within four hours of using TrendMiner, chemical engineers learned why a batch reactor produced some batches at a lower quality than others.
Learn how TrendMiner helped engineers identify a bottleneck that was preventing consecutive grade production and created a 16% efficiency gain.
